thinking about running nitrous
first off i have a 95 z28 camaro with 105k miles.
i was thinking of rebuilding the motor and throwing some forged pistons and rods in along with Lloyd Elliots LE1 heads and a medium sized cam.
With this setup i am hoping for around 350-375hp.
then i want to put on a 125 shot.
my questions are. will the nitrous hurt the motor if it is tuned for the heads/cam.
and vice versa will i be able to run the car on motor only if i tune it with the nitrous.
this is my daily driver so i need this to be a safe setup on both motor and nitrous.
thanks in advance
To have the best of both worlds on your tune for the motor then spraying it, get a timing tuner to back the timing down when you spray and then when you are on the motor you have the timing back at the motor timing. The timing tuner will only activate when you hit the spray. Make sure you pull out about 6 degrees of timing on that shot to be safe and then once you learn more about tuning put the timing back in if it is needed.
thanks in advance
