help please!!!
Old Sep 7, 2010 | 05:23 PM
01zb4c's Avatar
Default help please!!!
Ok guys its been awhile sence i wired up my last nitrous system and i have a few questions... 1. I have HSW mircoedge (used it in my camaro and loved it so ill use it) does anyone know a place that shows where to wire (splice) everything into? like the TPS, WOT ect, basicly a wiring digram for everything would be nice.. 2. I have a 4.8L going to spray a 100 shot, I think through a 78mm NOS plate, what plugs should I run? this is a DD so keep that in mind... any help would be awesome, i got the bottle mounted ad the noids, so i'm pretty close... THANKS guys!
if u have any questions ill do my best to help.
i posted on the performance truck side and didnt get any responces... and im needing fast help im ready to spray agin
Old Sep 7, 2010 | 05:44 PM
same o'j's Avatar
i run window switch in mine
as i know the green wire will be for the tach wire and you should give the signal from the green wire in the right side from coil
for the TPS wire signal this will be connect with the blue wire for the TPS sensor harness
hope that's clear
thanks
Old Sep 8, 2010 | 09:15 PM
01zb4c's Avatar
come on guys help me out....
Old Sep 8, 2010 | 11:21 PM
dnkynrbk's Avatar
I would look here man http://www.nitroustech.com/forums/showthread.php?t=64
I would wire the TPS to the blue wire at the throttle body I think its the same for trucks dont quote me. I got my tach wire off pin of the computer.
Old Sep 9, 2010 | 11:54 AM
01zb4c's Avatar
that is going to help... yea thats where i wired all mine in to on my camaro was right at the comp... i just need to find the tach wire on a silverado
