Pictures of Nitrous Dave N20 and Stand Alone and NANO install......
The shifter is a B&M Ratchet Shifter - part 35498. It is designed to work with the 4L60E transmission and can handle the OD (4th). It uses a lock-out feature which requires you to pull up on the handle to move between Park and Reverse or Drive. Once in Drive you ratchet it up or down through the gears. When installed in the stock console bucket the red shifter pointer will read Neutral when in reverse and 3rd Gear when in Drive - other than that it fits and works perfect!
![](http://i615.photobucket.com/albums/tt232/tdegrac/DSCF3257-Conv1.jpg)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I'm really diggin the whole car, the nitrous just tops it all off
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
OWN3D BY MY PROF!
The piping is only 3 1/2 inch due to clearance issues. Would of had to move the radiator support down about a half inch to fit the 4 inch pipe and decided that was a winter project. The picture below shows a little more of the piping and filters. Not sure of the bend details as I had it custom fabricated by a local guy who does great work.
http://i615.photobucket.com/albums/t...3257-Conv1.jpg
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
