I have a couple of N2O questions. Zex kit, Nitrous outlet plate......
I have a Zex wet kit that I bought off of a guy on here that I put on my car. Its the Zex kit where everything is all built into one control module (idk if thats how all zex kits are made or not) but the guy I bought the kit from said it was a 125 shot kit. My question is, can I run a 150 shot through this kit or is the 125 determined by the solenoid box and not the jets?
Also I bought a 90mm plate kit from Daves nitrous Outlet and I was reading when I searched about this that you had to use the jets that came with the plate instead of the jets that came with the nitrous kit. Is this true?
Thanks for all the help guys!
The Zex system will flow the 150. I would go by our jetting.
Assuming you are pulling fuel from the fuel rail the starting point on the tune up calls for a 62nitrous and a 38fuel. To be honest with you the 38 should be to rich and odds are you will ned up with a 33 jet on the fuel.
Dave
Dave
