2 step and WOT switch?????
Old Sep 15, 2010 | 01:11 PM
AChotrod's Avatar
Default 2 step and WOT switch?????
I have a 6spd car, 2 step and a N/O progressive controller, how do I set it up so I can use the 2 step without activating the nitrous since the car is at WOT on the 2 step?
Do I just not put the pedal to the floor using the 2 step? Do I set the nitrous to come on at a higher RPM then the 2 step is set. Can I not really use the 2 step?? How do I make this work??? Planning on testing at the track this friday.
Thanks
Mike
Old Sep 15, 2010 | 02:21 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
The way we do that is running two relays. One for the WOT switch and one for the two step.
http://nitrousexpress.com/product-details.php?id=228
Old Sep 15, 2010 | 04:02 PM
AChotrod's Avatar
Well there is no actual WOT switch the car has a progressive controller wired to the TPS.
Old Sep 15, 2010 | 04:12 PM
Formula383's Avatar
2 relays will work but you can do it with one like I did. Not sure how you would have a brake on an M6 LOL. I'm also assuming you already have a relay powering your solenoids.
Go get a 5-pin relay instead of the normal 4-pin like your kit came with. For my setup I use a stretch cord with a button on the steering wheel. I can probably get you a diagram later but this is how it works. When you push the button, 12V will activate the 2-step and deactivate the nitrous by breaking ground to the nitrous relay. When you let go of the button, the 2-step is deactivated and the nitrous is activated as long as you are at WOT and within your RPM window.
Old Sep 15, 2010 | 04:18 PM
You win this round
That is a 5 pin relay and I did mean 2 step. Formula383 has it right.
Old Sep 15, 2010 | 04:37 PM
AChotrod's Avatar
I was told I didnt need the relay with the progressive ??? it uses a fuze looking deal(forgot its real name) instead.
I have the 2 step hooked up to a stretch cord and mounted on the wheel also, just not sure how I would hook it all together. A diagram would be great.
Old Sep 15, 2010 | 04:51 PM
Formula383's Avatar
It can still be done without the relay. Instead of breaking ground to the solenoid relay you can break 12V or ground to the solenoids. You still need the 5-pin relay though.
Old Sep 15, 2010 | 04:54 PM
http://www.nitrousexpress.com/Instru...rans_brake.pdf
This but two step in place of the t-brake.
Old Sep 15, 2010 | 06:20 PM
AChotrod's Avatar
I might have a 5 pin at home. Sux my computer at home is busted. Its gonna be hell trying to remember this with no help if I get lost. Excuse my crappy drawing but here is how mine is wired except the 2-step(not pictured) comes out of the MSD Dig6 box. Should be just like yours Kyle. Where does the relay come in a what should it go to?
Old Sep 15, 2010 | 10:11 PM
Formula383's Avatar
Mike, I found my diagram but it's scribbled down. The progressive makes it a little different from mine. I've got a single stage controller with no progressive. I'll see if I can figure something out for you.
Old Sep 16, 2010 | 11:04 AM
Formula383's Avatar
Here ya go man. Just made this diagram for you this morning. This is how I have mine wired in. I know this doesn't work exactly for your system but you should be able to tell how the 5-pin relay switches power between 2 circuits and apply that to your setup. I think you can use the 4-pin relay to break ground to the solenoids by changing a few wires around. But in the end, it looks like you will need 2 relays to solve this problem due to the controller.
Old Sep 16, 2010 | 12:21 PM
AChotrod's Avatar
Awesome! Ill call the Outlet if i get stumped. Thanks a ton!
