Purge install question
Old Sep 16, 2010 | 08:07 AM
armyboyatc's Avatar
Default Purge install question
I have a Zex kit, the one that has both the fuel solenoid and nitrous solenoid all built into one box. I want to hook up a purge to it and I'm not sure how.... I have the Nitrous daves big show purge kit but I need to know how to hook it up to the Zex box. Thanks for the help.
Old Sep 16, 2010 | 09:00 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
You will have to use the supplied manifold and attach it to the Nitrous inlet of the box.
Then put the 1/8npt x 1/4npt union in the side port of the manifold.
The 1/8npt side will go in the manifold.
The 1/4npt side will then go in the inlet of the purge fitting.
The 1/8npt x -4 will go in the bottom exit of the purge solenoid and route the tubing where you like.
Dont forget to loctite or thread paste the plug in the other side of the manifold.
Old Sep 16, 2010 | 02:47 PM
Chris@NitroDaves
Guest
Posts: n/a
What Grant said
Old Sep 19, 2010 | 10:02 AM
c6 batmobile's Avatar
Wiring is simple too. You just need a power and ground. Run it from your 12v post to the switch and then ground it. I just hooked mine up. Piece of cake.
