Spark Plug Confirmation
Old Sep 21, 2010 | 10:32 PM
matt.martin87's Avatar
Default Spark Plug Confirmation
I just bought a Zex wet kit that will be spraying anywhere from 75-125 shot.
My car is a 98 Trans Am with a lid and open cutout. I would like to know if br7ef plugs are too cold for my setup. I don't plan on making any further mods anytime in the near future.
Old Sep 22, 2010 | 09:09 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Thats the plug I would recommend.
Old Sep 22, 2010 | 09:28 AM
ryarbrough's Avatar
That's the one!
Old Sep 22, 2010 | 10:22 AM
Just needed that final nod. Thanks.
Old Sep 22, 2010 | 10:46 AM
Final nod. Good luck sir.
Old Sep 22, 2010 | 11:20 AM
01SOMZ28's Avatar
Run them when you spray and change them when you daily drive. You'll notice that it will run like **** if you daily on those plugs.
Old Sep 22, 2010 | 11:38 AM
ryarbrough's Avatar
It won't if your tune is clean at idle. Leave the plugs in on the street and make sure the tune is right. If you foul a 7 street driving it's because you've got too much fuel in the idle circuit, not because the plug is aggressive.
Old Sep 22, 2010 | 11:48 AM
01SOMZ28's Avatar
I've noticed a difference (along with a handful of people i know) in how our cars run with this plug. I put it in when i go to spray and change them out when i'm done.
Old Sep 22, 2010 | 11:51 AM
ryarbrough's Avatar
I just want to represent that any differences are not the plugs fault...
If you're running around with an idle/part throttle tune that's a bit too rich a hotter plug will mask that. You put the colder plug in and are like, "WTF, this idles and drives awful."
I drive my car all the time with 9's in it, and it runs pretty much exactly the same as it does on a 7 or a 6. I got tired of having different heat range plugs sitting around, so I fixed the real problem.
Old Sep 22, 2010 | 11:55 AM
01SOMZ28's Avatar
hmm, so what you're saying is is that i should get my car retuned? Because it idles like **** with these plugs.
Old Sep 22, 2010 | 11:57 AM
ryarbrough's Avatar
Yes... What you have to realize is that the tuner can only compensate for what he sees. If you had a hotter plug in when it was tuned, it would have probably acted pretty normal at idle. Put the colder plug in, and it runs like **** because it was really too rich all along. Nothing the tuner could have done to anticipate that, just the way the cookie crumbles.
I am pretty amazed that a 7 is causing it to act up though.... It's not like you've got a really cold plug in there.
Old Sep 22, 2010 | 12:06 PM
01SOMZ28's Avatar
Once i start driving it drives fine but sitting at a stop light it idles terrible and almost dies. Never did that with a TR6.
I guess i never thought of it the way you just explained it. Makes sence though, because i've never ran a br7 on the dyno
Old Sep 22, 2010 | 12:46 PM
n20kid's Avatar
It will run a little worse at an idle over the tr6 with the tune for the tr6... If u have it tuned with the 7 it will run better and cleaned up alot at idle seeing as it is a colder plug.
