DP TNT F4 users
Old Jan 27, 2004 | 10:23 PM
silverTA's Avatar
Default DP TNT F4 users
am thinking about getting one
is it easy to install ????(i instaled alot of NOS dry and NX wet kits in ls1)
do u all think it will be a good choise to get this kit or there is a kits better...
does some one got pics of it instaled
thanx
Old Jan 28, 2004 | 01:11 PM
Vents's Avatar
well, it's a TON of work, but they net the best results. w/ the gear/tire and trany combo you run, you're good for 10's on a small 150 shot or so. ;D
BTW, how'd the cobra race go?
Old Jan 28, 2004 | 01:30 PM
monkeyboy's Avatar
f4 only comes with a 300-600 shot pills, how can you use 150? unless they now sell them will lower shot.
Old Jan 28, 2004 | 01:43 PM
taqwache's Avatar
thanx
if your mechanicaly inclined they are not that bad to install. any DP will be just as hard to install unless you get a bolt on kit like the NXL or the NOZZLE. although you will not get as much power out of them.
Old Jan 28, 2004 | 02:52 PM
monkeyboy's Avatar
and why would you wanna run a DP on 150 shot anyway?
Old Jan 28, 2004 | 03:31 PM
silverTA's Avatar
sorry i forgot to till u about it ,,i got his 500$ and i didn't spray until i shift 3rd
Old Jan 28, 2004 | 03:35 PM
silverTA's Avatar
i'll run 200 shot(i'll start with )
do i have run a fuel system for the DP ,or i can use a regulator at the fuel rail set at 6 psi
Old Jan 29, 2004 | 08:08 AM
taqwache's Avatar
defenently run a seperate fuel cell.
