Do I need fuel mods?
Old Oct 2, 2010 | 03:07 AM
Lammy's Avatar
Default Do I need fuel mods?
I've got a 98 camaro. It's cam/exhaust. I'm planning on spraying a 125 wet shot, and possibly a 150. It has stock injectors and stock fuel pump. Do I need to upgrade either?
Old Oct 2, 2010 | 08:26 AM
NVR_SPDS's Avatar
Throw in a pump and hotwire kit. Both those things are a whole lot cheaper than an engine.
Old Oct 2, 2010 | 01:17 PM
soundengineer's Avatar
or buy the Racetronix kit that has the pump and the wiring upgrade combined together....
then you dont need the separate hotwire kit, and everything is plug and play, no wires to splice.
Old Oct 2, 2010 | 01:21 PM
no1izspeshl's Avatar
I would recommend at least SVO 30lb injectors if you can swing the extra costs. All in all, should be around $400 or so for fuel upgrade. Better that price than a new engine price.
Old Oct 3, 2010 | 12:53 AM
Lammy's Avatar
Went ahead and ordered that fuel pump kit with the wire upgrade. It'll help me keep a piece of mind. Thanks guys!
Old Oct 3, 2010 | 01:00 AM
wbb's Avatar
wbb
what is the racetronix kit got it on my car and dont have a clue i'm learning as we go???
Old Oct 3, 2010 | 12:36 PM
NVR_SPDS's Avatar
Thats what i meant, thanks.
Glad to hear. I think fuel system upgrades are always a good idea when doing more serious mods.
This should help: http://www.racetronix.biz/itemdesc.a...%2D001&eq=&Tp=
Old Oct 3, 2010 | 09:04 PM
rem308winvtr's Avatar
racetronixs kit with a hot wire will be your best bet but dont do over a 150 shot
Old Oct 3, 2010 | 09:20 PM
racetronix kit doesnt need a seperate hotwire kit...
it already comes with the upgraded wiring... just be sure to get the upgraded ground wire to... buy the Kit, not just the racetronix pump
Old Oct 4, 2010 | 12:57 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Moving to N20.
Old Oct 4, 2010 | 05:09 PM
Chris@NitroDaves
Guest
Posts: n/a
You should be ok with the factory injectors but you will need to upgrade the fuel pump. As others have stated i'd suggest going to with the Racetronix unit.
Pump
http://www.nitrousoutlet.com/catalog...0&product=3327
Harness
http://www.nitrousoutlet.com/catalog...3&product=3720
