Nitrous/RMVB TH400 guys...
I asked the question in the auto trans section about shutting the car off in 3rd after you cross the line and was told not to do so..
Do you guys normally cost to the turn off with the engine running then shut it off and in doing so wouldnt that effect the reading on the plugs...
I just kill it in 3rd.
People have done it without whatever modification it is that keeps the overrun clutches from engaging for a long time and still never hurt anything though.
I slow the car down to around 40 or so get it into neutral and shut it off. Yes that isnt the perfect way to get it done, but we can still get a good read on them.
for such a strong trans, they are apparently easy to **** up if used wrong.
And as far as the down shift, you can do it if you are careful - you have to come on the gas very easy and you will feel it catch... then you can go WOT... used to do it all the time to those 6 speed guys who thought I couldn't down shift when playing on the street.
