HSW plate users inside
Old Oct 14, 2010 | 04:14 AM
LS1TRUCKGUY's Avatar
Default HSW plate users inside
I am shooting for 11.8 AFR. i am using a .052 n20 jet. what fuel jet are you guys using? HSW calls for a .028, but im sure thats gonna be fat. stock fuel pressure btw.
thanks in advance
Old Oct 14, 2010 | 04:52 AM
itsslow98's Avatar
im running a .031 through my nozzle witht he .052N jet. My A/F is 12.5.
Old Oct 14, 2010 | 07:13 AM
Carter01's Avatar
thanks in advance
So have you sprayed the truck with the 20 jet? If so what did you get on a/f? If you haven't sprayed the truck yet then i would suggest not going with that low of a jet until you see what your truck likes (progressively drop jets by 2s, try 28, then 26 etc..). Also what kind of pump are you running and what all safety equipment do you have?
Old Oct 14, 2010 | 08:13 AM
Twotonefreak's Avatar
Start off with the recommended jet and work your way down from there. Don't go off the a/f gauge, go off the plugs.
Old Oct 14, 2010 | 10:09 AM
Carter01's Avatar
Twotonefreak is absolutely correct, the plugs will tell all. I don't use an a/f gauge. They are a good tool for tuning but they can't tell you which cylinder is the leanest since they take a cumulative average. If you talk to some of the heavy hitters spraying over 300 they will tell you every motor reacts differently, some like to be a little richer and some don't.
Old Oct 14, 2010 | 11:53 AM
I know I'm spraying more but since you asked for jet sizing we're using. I run a 72N and 33F.
Old Oct 14, 2010 | 12:12 PM
LilJayV10's Avatar
You can start with using the gauge till you are close then fine tune with reading the plugs.
Old Oct 14, 2010 | 03:39 PM
i have sprayed the truck on the 50 shot twice just to make sure the kit was functioning properly. i havent sprayed it with the 100 shot yet. for safety equip, i have a bottle heater, and microedge controller. just getting a ballpark, cause i need to get some jets. i didnt want to buy a bunch if i didnt need to.
Old Oct 14, 2010 | 03:42 PM
i have tr6's in it now. i plan on getting a few sets of br7ef's this weekend for a few 1/8 mile hits and to get the suspension dialed in for the n20
Old Oct 15, 2010 | 02:49 PM
also, does it make a difference if i used wide stem or narrow stem jets? will the narrow stem jets work?
Old Oct 15, 2010 | 07:28 PM
anyone?
Old Oct 15, 2010 | 10:51 PM
I've used both with no effects either way
Old Oct 16, 2010 | 02:03 PM
ok good to hear. i didnt want to pay $12 shipping for jets
