What hp shot needs aftermaket fuel pump?
Old Oct 15, 2010 | 08:37 AM
john shea's Avatar
Default What hp shot needs aftermaket fuel pump?
I am running a Harris wet plate. If I go over 100 shot do I need a fuel pump
and am I safe at 75 to 100 without pump?
Old Oct 15, 2010 | 10:17 AM
JM0523's Avatar
ive heard of quite a few people spraying 150 on stock timing, stock pump, with just high octane fuel and 1 step colder plugs, i guess it all depends on how safe you want to be.
Old Oct 17, 2010 | 02:24 PM
lsjuanmike's Avatar
You should be fine at that level, but step it up slowly and monitor how it's doing. I ran lots of passes at 150 wet shot on stock fuel pump with no problems.
Old Oct 17, 2010 | 02:47 PM
01SOMZ28's Avatar
My fuel system is 100% stock and i've sprayed 100, 150 and 175.....i would not go over 150 on a stock pump though.
Old Oct 17, 2010 | 02:56 PM
BLK02WS6's Avatar
It really depends on the total horsepower the car is making... mods + nitrous... If you are near 400 rwhp, its time for a pump.
Old Oct 17, 2010 | 03:23 PM
01SOMZ28's Avatar
I made 495rwhp 549rwtq on the stock pump, but i REALLY need to get a different pump.
Another time i made 455rwhp 587rwtq, stock pump...
Old Oct 17, 2010 | 03:39 PM
BLK02WS6's Avatar
Your 119 MPH trap speed says that your dyno numbers are from an EXTREMELY generous dyno...
Old Oct 17, 2010 | 07:30 PM
KFZ)^'s Avatar
With my stock pump, no hotwire, "42lb" injectors, and stock returnless 2001 Z06 fuel rail, I can't spray bigger than 70-75 hp with a wet shot off the fuel rail thru a "plate".
If I put in larger jets, it misfires from going lean due to the "shock" of the nitrous hit on the fuel side to the rear-mounted-regulator-type system.
I plan to "devolve" the car to 97-98 Vette return-style system since budget excludes a stand-alone right now. An upgraded fuel pump is key also.
Old Oct 17, 2010 | 07:37 PM
kinglt-1's Avatar
How can you make that assumption without knowing the DA??
Old Oct 17, 2010 | 08:37 PM
99corvette's Avatar
Its based on overall hp. Most pumps max out somewhere around 450rwhp
Old Oct 17, 2010 | 09:58 PM
01SOMZ28's Avatar
Who cares what a dyno says, its a tuning tool and i've had more than one dyno tell me the same. After i get my nitrous issue fixed (cutting in and out up top) i should be over 120+ in the 1320.
