Nitrous gains seem a little lacking
Old Oct 25, 2010 | 08:39 AM
SuperSlow02's Avatar
Default Nitrous gains seem a little lacking
Does this sound right or and I missing something? I went from 7.51@92mph 1.64 60ft to a 6.94@99mph 1.51 60ft. Both times I left at 4k off the trans brake, which seemed to get the best times. The car felt great, I didnt get to check my plugs due to how busy the track was. The set up is basically cam only with a th400 with a supposed nitrous converter, 4.11 rear gear and 28in tire. Is this a pretty weak gain for a 150 hit?
Old Oct 25, 2010 | 08:45 AM
Carter01's Avatar
On a 150 shot I would go 6.72 at 101 dropping from a best of 7.52 at 92. Do you have a window switch? Are you getting any tire spin? We basically have the exact same setup so what plug are you running? Gap?
Old Oct 25, 2010 | 09:46 AM
Yea, window is set from 4100-6600, and shifting at 6500. Absolutely no tire spin. I'm running a br7 gapped at .32. I don't know the DA but air quality was outstanding
Old Oct 25, 2010 | 09:54 AM
We did have video....but somebody stole my friends camera out of his car....and I did t realize how great the IPhone 4 was at night video...lol or I'd have my wife tape
Old Oct 25, 2010 | 11:00 AM
custm2500's Avatar
Ph.D. in HUBRIS
I take it you have a big stall? If you stall is anything shy of 4100(on nitrous) then you are leaving allot on the table by not spraying out of the hole. Regardless not too shabby being you should drop around 1.5 in a full 1320. therefore .75ish is what you would look for in a 1/8th.
Old Oct 25, 2010 | 11:09 AM
r572cobra's Avatar
when you guys say ,spray out of the hole,that it mean you set your ws lower than what you leave on the trans brake.
Old Oct 25, 2010 | 11:30 AM
I wasn't spraying the converter while on the transbrake....still not too comfortable with doin that. But as soon as I let the button go. The nitrous was active. I've just been getting the feeling the converter is the issue.....fuddle ftl
Old Oct 25, 2010 | 11:51 AM
Carter01's Avatar
How much timing?
Try lowering the WS to 3k and see how it does. I had mine set at 4k and was pulling 1.44, went to 35 and went 1.41, now going to 3k hoping for 1.3s. Along with some other suspension tweaking.
Old Oct 25, 2010 | 11:58 AM
Not sure on total timing but we pulled the usual 6*. How will setting lower help if I'm leaving at 4k? Learn my noob *** lol Im done at the track this year unfortunately....cold times are upon us
Old Oct 25, 2010 | 12:11 PM
Carter01's Avatar
LOL... I said the exact same thing a month ago. It's really hard to expalin. It seems that if you have the WS set right where the TB leaves off you will be spraying right the hole right? Well I thought the same thing but I listened to the experts and lowered mine and the car kept getting faster. I could probably expalin it in person but it's really hard to type out. Just try it ans see if it helps, just make sure your timing down in those cells is right.
Old Oct 25, 2010 | 12:22 PM
I'm understanding it lol. I think we started the timing pull at 3200. I thought about lowering it but was unsure of what would happen
Old Oct 25, 2010 | 01:18 PM
Carter01's Avatar
I just went down to 3k and pulled the timing there as well jus tin case. It will probably never see that low of an rpm but I always error on the side of safety
Old Oct 25, 2010 | 02:00 PM
Unforntunately my tuner lives almost 2hrs away.....so I think I'm stuck at 3500 for right now. I am itchin to hopefully try the track again but I forsee last Friday being the last t&t. Now when u set yours to come on before the brake, are you actually spraying while on the brake? Or are you flashing the **** put of it with the nitrous
Old Oct 25, 2010 | 02:11 PM
camscam02's Avatar
converter
Old Oct 25, 2010 | 02:30 PM
Carter01's Avatar
No, it's still not going to spray on the converter, just flashing it like you stated.
Old Oct 25, 2010 | 05:24 PM
Originally Posted by camscam02
converter
Can I barrow yours
Old Oct 25, 2010 | 05:25 PM
Thanks for the help carter
Old Oct 26, 2010 | 12:06 AM
camscam02's Avatar
Can I barrow yours
I know of a guy that can get you one very very close to mine!
