New to Nitrous.....Check my list please
I've done alot of reading in the stickies (so much that my brain started hurting lol) and I think I have a solid list, but wanted to run it by everyone on here for suggestions and or additions to the list.
A brief setup of what I will be running come next season:
1998 Z28 M6
9" w/4.11's 27x11.50 QTP
cammed and all bolt ons
42# injectors and will be upgrading the fuel pump since I'm still running the stocker. Don't want any costly failures right of the bat.
TR6's
Nitrous tune
I'm setting my budget for new everything, but if I run across deals on things I'll need then I'll consider it.
Here is the list of items I'm looking at with links included:
Nitrous Outlet GM EFI LS1 Plate Systems(Wet)
https://www.vengeancerd.com/ecart/pr...stems%28Wet%29
Brand X Accessory Packs Stg 3
https://www.vengeancerd.com/ecart/pr...ccessory-Packs
98-02 HSW Camaro/Firebird Ashtray Switch Plate (Manual)
http://www.ws6project.com/user_stor/...oducts_id=2639
93-02 LS1/LT1 Walbro 255 LPH In-Tank Fuel Pump
http://www.ws6project.com/user_stor/...oducts_id=2474
HSW WOT Switch & Bracket
http://www.ws6project.com/user_stor/...oducts_id=2675
Anything else or less? Not sure if I'm going overboard or not. Just wanna make sure I have everything I need. I'm open to suggestions, but overall would like to keep it as simple as possible. Don't know if it matters but the way I launch my car I'll pretty much be spraying out of the hole. WOT as soon as I dump the clutch. TIA
This could change based on what size hit you plan on running. What cam is in the car? What does it run now?
Here's what's included:
Remote opener
bottle heater
remote digital gauge
WOT switch
dual stage digital electric window switch
TPS sensor
ashtray panel
2 bottles-1 is full
NX solenoids
purge
NX shark nozzle
main line
fuel line
timing retard
all wiring
mounting bracket for bottle
All for $900. Good deal?
