Are all AN fittings good enough for nitrous?
I was trying to get a 6- 45 degree female/male fitting this afternoon from a local speed shop. He said that he didn't know if the fittings he had supported the high PSI of nitrous. He also said that there are two kinds of braided lines, a rubber line and a teflon coated line for high pressure. He has EARL and Aeroquip fittings.
Thanks for any info.
Guest
Posts: n/a
Earl's and Aeroquip make fittings to use with the teflon nitrous hose. You need to make sure you are using those fittings becasue nothing other than those will work correctly.
http://www.holley.com/EarlsCatalog/C...?pageNumber=74
Thanks for the reply Chris. I just shot you a PM not to long ago asking about some fittings.
So your normal 90 degree elbow will work coming off the noid, or in my case zex box?
I got what I was told a hydraulic fitting, it fit on my fuel and nitrous in.. then I got a reducer? To go on my passenger rail to the fuel in.. I have fast rails so the fuel on line wouldn't fit the adapter.
thanx guys!
