Will this 45 degree fitting hurt flow?
Old Nov 12, 2010 | 08:03 PM
LilJayV10's Avatar
Default Will this 45 degree fitting hurt flow?
I am in the process of hooking my nitrous feed line and blow down tube. I am using HSW filter kit which is -6 line to the filter then I am running -4 to the solenoid. I am wanting to run the feed line and the blow down line under the rear driver side back seat.
Doing so puts a bend in the feed line which makes it kinda difficult to put the line on. I don't want to worry about cross threading it so I thought about putting a 45 degree fitting off the bottle to help aim the line back.
What do you guys think? I will be spraying 125 shot at the most.
Old Nov 12, 2010 | 11:03 PM
krissoto's Avatar
Should be okay to put a fitting in there. Or you could poss look at putting a spacer in the front side of you bottle brackets to raise it up some, and then you won't affect the flow.
Old Nov 24, 2010 | 12:01 AM
LilJayV10's Avatar
This is what I ended up with.
Old Nov 24, 2010 | 05:29 PM
Chris@NitroDaves
Guest
Posts: n/a
The 45* fittings will not hurt the flow at all.
Old Nov 24, 2010 | 09:05 PM
a4ls2goat's Avatar
will a 90 degree fitting right off the bottle hurt flow?
Old Nov 24, 2010 | 11:24 PM
LilJayV10's Avatar
Thanks for the response Chris.
