fogger or direct port
Split your 200 up however you want based on what your trying to do. If you are traction limited maybe make your first stage 50 or 75 so that you can spray it in first gear. If you want to do a lot of roll racing and have a little extra hp just incase make your first stage the big one 125 to 150.
If it were me I wouldn't spray 200 through a nozzle, I would look into a dual stage plate.
This gives me the ability to program both stages to work but I can choose on the fly when or if to activate the second stage.
Dave
Dave
The mixture is in and out in a split second. They key is tune up. Now with every intake there is a point of delivery issue. The LSX intake design works pretty good with a wet system.
We have used our plate for 250 shots on more cars than I can count.
Dave
Dave
I might not be as high dollar as you two, but I'm 5 grand in and the short block is not even assembled yet. Still got about another 5-7 grand to go and thats just an estimate, so it can only go higher.
