I have MS4 ported LS6 heads and the rest of the goodies with that. Ls6 intake and a ported and polished TB. No upgrade to fuel yet but will replace the pump if I spray. Future plans are to run this spraying around 150 then probably step up to a 90 or 92mm intake and TB. Figured it would be an easy upgrade. After that build something big cubes. And damn you for extending your sale lol
Ok, So you have a couple of options. being that you have a 78mm intake now you could do the 78mm plate kit and upgrade the plate to what ever matches the intake size in the future or you can do a single nozzle.
Good thing is if you do the 78mm plate now our plates sell like hot cakes used so selling it to upgrade to a different size will be no problem.
You will deffintly need to upgrade the fuel pump.. I would suggest a racetronix system and then you will be good for about 650 rear wheel hp.
I can build you a quote with fuel system and all. Then email it to you.
Just shoot me a pm with the following
First and last name
Email address
Phone number
Shiping address
