Looking to get in the Nitrous game
Old Nov 26, 2010 | 12:34 PM
CNTLSE 1's Avatar
Default Looking to get in the Nitrous game
Ok I have a 98 Trans Am LS1 heads cam motor with 57xxx miles on it. I'm looking to get into the nitrous game but dont know a whole lot about it. So I have been looking at a few packages and thought I would get your guys opinion.
http://www.nitrousoutlet.com/catalog...5&product=4091
http://www.nitrousoutlet.com/catalog...5&product=2794
Something like these is what I am looking at. Please give opinions and advice. Thanks
DJ
Old Nov 26, 2010 | 05:22 PM
ND2RACE's Avatar
Those kits are the same with the exception of the hard lines so you get a cleaner install, I'd buy the first one, but thats a matter of opinion.
There are many threads about thsi type stuff, and reading the stickies about nitrous should help you decide, however your post isn't very specific about what you would like to know.
Old Nov 26, 2010 | 08:12 PM
CNTLSE 1's Avatar
I have read the stickies. Just curious if there is anything else I would need tor un this safely. Pretty sure I will need new injectors as mine are almost already maxxed. Its an M6 car. what other info do you guys need? Thanks for the help
Old Nov 26, 2010 | 10:06 PM
slammin86's Avatar
Injectors don't matter on a wet kit. Look into a fuel pump if you do not already have one.
Old Nov 26, 2010 | 11:54 PM
CNTLSE 1's Avatar
do you run an inline pump or change the one in the tank?
Old Nov 27, 2010 | 02:10 AM
ZTwentyAteU's Avatar
Just get you a 255 intank. $100 bucks all day. You will have a blast with a wet plate kit, or even a single nozzle. A HSW nozzle kit is cheap and effective. I duno if they are sponsors on here don't wana step on toes. Make sure whatever you get, get the big solenoids, the little ones on most kits wont spray past a certain hp level.
Old Nov 27, 2010 | 08:04 AM
slammin86's Avatar
The little ones are usually good for 175 to 200 hp, which is likely more than enough for someone just wanting to get into the nitrous game.
Old Nov 27, 2010 | 09:34 AM
CNTLSE 1's Avatar
Yeah I am planning on a 125-150 shot max right now. Still on stock bottom end. I am very heavily leaning towards the first kit listed. plus right now it is 15% off. That is a dry kit correct?
Old Nov 27, 2010 | 09:44 AM
87silverbullet's Avatar
No. Thats a wet kit.
Old Nov 27, 2010 | 01:32 PM
CNTLSE 1's Avatar
well even better then. So with that kit I should upgrade the fuel and be good after a tune? Thanks for all the help guys
Old Nov 27, 2010 | 01:39 PM
SuperSlow02's Avatar
I'd suggest a HSW microedge. Being a m6 car you'll need the Saftey features. And don't forget colder plugs
Old Nov 27, 2010 | 03:49 PM
slammin86's Avatar
Upgrade the fuel pump and pull some timing out somehow. I think the kit comes with br7 plugs, use those. I also suggest buying a wideband.
Old Nov 27, 2010 | 05:05 PM
CNTLSE 1's Avatar
So the first kit is a option for the a beginner? upgrade the fuel pump. and will get a full tune afyer install along with maybe a wideband? Just not what kit is the best to start out with
Old Nov 27, 2010 | 06:20 PM
slammin86's Avatar
There really is no best kit for everyone, it all depends on your needs and budget. You could shop used and piece together a kit and save some cash, or you could buy all new and be done with it.
Old Nov 29, 2010 | 02:06 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
I see with lots of questions this can be confusing. If you would like I am Here till 5:30 central time. We can sit down and go over everything so you will have a better handle on some of the in and outs of nitrous. Much simpler after a conversation.
Old Nov 29, 2010 | 04:28 PM
CNTLSE 1's Avatar
Do you guys offer complete kits?
Old Nov 29, 2010 | 04:57 PM
Nitro Dave's Nitrous Outlet's Avatar
Looks like you are on track.. Lets talk alittle more about what you have..
You said you have a heads and cam set up.
What intake?
Have you upgraded the fuel pump yet?
What are your future plans?
If you would rather call me at the shop our toll free number is 1-866-648-7637
Otherwise I can respond here.
Dave
Old Nov 29, 2010 | 05:28 PM
CNTLSE 1's Avatar
I have MS4 ported LS6 heads and the rest of the goodies with that. Ls6 intake and a ported and polished TB. No upgrade to fuel yet but will replace the pump if I spray. Future plans are to run this spraying around 150 then probably step up to a 90 or 92mm intake and TB. Figured it would be an easy upgrade. After that build something big cubes. And damn you for extending your sale lol
Old Nov 29, 2010 | 05:33 PM
Of course sir. From Mild to wild. We all the safety features from Fpss to remote bottle openers. NX carries it all.
We have been putting out high quality Nitrous parts for over a decade. Happy to have you on Team NX.
Old Nov 29, 2010 | 05:41 PM
CNTLSE 1's Avatar
on your website or easiest to call?
