what should i go with
Thanks
Thanks
Anyway, select the injectors that your tuner have all the data for them, for example .. SVO 30lb or 42lb are good upgrade since tuners can find the required data that help drivability alot while in other hand FAST 36lb injectors data cannot be find .. which in bigger cams you may have drivability issues due to lack of injectors tune
I would change what you want to change on your car (fuel pump,rails,cam) before you get your tune done. You need anything hollar.
Thanks
