blow down tube..re routed
so i have my bottle mounted in between the rear seats(formula) and have not mounted my blow down tube yet because I dont want to drill a hole in the floor..Does anyone sell a blow down tube/kit where it can be routed to mahbe use one of the holes for the rear seats? if so can you post a link or part number
Guest
Posts: n/a
Guest
Posts: n/a
This one will work for what you are wanting to do.
http://www.nitrousoutlet.com/catalog...4&product=3832
The hole in the floor board should be 5/8 to fit the bulkhead through. All I had was a 3/4 and that's why I had to put the washer there. I probably would have put a washer on it regardless because the sheet metal there isn't very thick.
