Br7ef or br6ef
As for the tune say your car likes 30* WOT of timing then you would reduce timing by 4* for 100 shot from say 2800 or 2900 rpms to 8000.look and see where your cylinder airmass is during WOT and then drop back below the lowest point to be safe. So if your lowest g/cyl/sec is .70 the lets go with .60-.62 through 1.0. take 4* out of those cells and your set for nitrous and N/A should only drop a little in torque.
Tuned for NOS 35 Fuel 18 with 11.8-11.9 A/F
I am running tr6 and was advised to run br6ef. Should I consider the br7ef?
My tuner wants to pull another degree of timing and tune for the A/F.
I have a wideband in my progressive controller.
Is this still necessary if I go to a non projected tip or a step colder non projected and
switch the jet from the 35 to the 41 and say 22 for gas while I watch the AF under full throttle, then say go to 20 gas jet, if I need to lean it out a little while watching the A/F? I also have the safety cutoff for the nos based on the A/F range I select or the pressure I select.
I am considering the different plug and then driving to tuner if necessary which is
3 hours from my home.
The reason I am asking this is because of the small increase in jet size.
Also the car is my DD.
I will order some 7 with the non-projected insulators.
Any reccommendations on the gap? 33 ok?
You'll love the V on nos.
