Cold Fusion----anyone ?
Old Dec 31, 2010 | 12:46 PM
1_bad_TA's Avatar
Default Cold Fusion----anyone ?
Going with a Cold Fusion 2 stage 90mm plate setup and their stand alone system. Question is, has anyone used Cold Fusion ? Anyone use their 2 stage plate setup or another similar 2 stage setup?
Old Dec 31, 2010 | 01:35 PM
TehGODofGreen's Avatar
I did a dry shot on a 3.8L with small cam had the kit on for about a year and a half ( I still have the n2o solenoid, brackets, bottle and purge kit for when I drop the new motor in ) the solenoids are nicely made they seem to stand up to heat and vibration damage. purge solenoid and distribution blocks are well crafted too, as far as the efi plates and carb plate setups im not sure how balanced or centered it is but the guys are helpful and knowledgeable about n2o and products the make and sell.
Old Dec 31, 2010 | 06:04 PM
ssexpress10's Avatar
Bought the complete like yours stand alone and 90mm plate. The noids are nice and do seem to be well made but anything around 950 to a grand and they wouldn't open so I bought some nx hitman and don't have any problems other than that no complaints.
Old Dec 31, 2010 | 11:13 PM
FlashWS6's Avatar
Destroyer of Exotics
i run a 2 stg coldfusion plate kit on my vette, i love it.
if your getting a 2 stg plate make sure its fbody specific becuz if you run the for a ls2/ls3 it will not work seeing how your throttle body cable will hit 1 of the sides.
Old Jan 6, 2011 | 08:47 AM
1_bad_TA's Avatar
I run an LS2 intake, rails, injectors, and a FAST TB on my car so no problems there. Already asked tech over at cold fusion about that.
Old Jan 13, 2011 | 05:07 PM
blackls1ta00's Avatar
im using a single nozzle kit and has been working great,id like to upgrade to a direct port 250 though with stand alone.
Old Jan 17, 2011 | 03:38 PM
TARZAN's Avatar
I typically use HSW on the fuel injected stuff, but I setup a Cold Fusion account for those seeking carb options and whatnot.
I've sold/installed probably a dozen or so CF pieces with no complaints at all. Seems to be quality stuff.
-Will
Old Jan 18, 2011 | 09:06 PM
GT_EATR's Avatar
Upgrading from 150 wet kit to a 250-300 wet kit... Any advice? Cold fusion or HSW... What setup should I go with.. I want a big hit of N20.
Old Jan 19, 2011 | 09:42 PM
TARZAN's Avatar
I would go with who you are comfortable with. Most nitrous vendors offer larger noids, lines, etc....I'd say to PM one of the vendors here (HSW is a sponsor here) and ask their feedback.
-Will
Old Jan 20, 2011 | 08:57 AM
AutomagicLS1's Avatar
I liked my cold fusion kit
Old Jan 21, 2011 | 06:06 PM
LSX-coupe's Avatar
I do not like thier fuel noids. I have had three get stuck open. Thier answer back was it was open for more than 10 seconds and burnt up. I told them yeah its on a 11 second car. It stuck open and flooded intake oh well. So no more. I only use nitrous outlet have had many systems from them no problems. Ask for chris Tell him Austin says Hi.
