head gaskets?
Old Dec 31, 2010 | 08:07 PM
juiced98z28's Avatar
Default head gaskets?
i have a stock 1998 z28 that i swapped in a 2004 lq4 into i had the block decked .015 to raise the compression i am running stock internals and a set of unported factory 243 heads.
i just added a 100 shot plate kit put down good numbers made 481 on spray ran about a bottle and a half threw it and i popped the head gasket. Thank god i caught it before it got bad just barley blew it never over heated it.
i am sure that using stock head bolts is probably what caused it i was wondering what kinda head gaskets should i use? i am definitely going to use a set of ARP head bolts this time. any ideas on what gasket i should be using?
Old Dec 31, 2010 | 08:25 PM
jmill96Z's Avatar
What hole did it pop on? I would fork out the cash and get some studs. Any damage to the heads?
Old Dec 31, 2010 | 08:34 PM
it was the number 3 cylinder no damage to the heads im pretty sure it just stretched the stock head bolts i am definitely going with either arp studs or bolts
Old Jan 1, 2011 | 09:33 PM
bigpat501's Avatar
cometic mls
Old Jan 2, 2011 | 08:58 AM
ATVracr's Avatar
Comtics and arp will help but I bet the problem is in the tune up.
You should never hurt something on a 3-4 second dyno pull.
The car has to live at least twice that long going down track.
Good luck getting it fixed.
Old Jan 2, 2011 | 03:12 PM
dnkynrbk's Avatar
Agree with ATV.
Old Jan 2, 2011 | 03:40 PM
ryarbrough's Avatar
Same here... You aren't making enough cyl pressure at those power levels to "stretch bolts". Post the tuneup so we can figure it out for ya. My bet is too much timing.
Old Jan 2, 2011 | 04:13 PM
87silverbullet's Avatar
Listen to ATV and ryarbrough. I hit a 200 on the dyno with only pulling 5* of timing and ran good on the dyno, stock head bolts and head gasket stayed together. Ran good, made 558 rwhp thru a th350 and a 12bolt. First pass at the track BOOM. Spun 2 rod bearings and bent those 2 rods. All from detonation. I think ATV might remember my thread.
Don't ask me why I only pulled 5* on a 200. ATV and ryarbrough already beat me up over it
Old Jan 3, 2011 | 02:50 PM
the timing on the motor is very conservative at 23* it has had about 2 bottles ran threw it.
all on the 100 shot i was going to spray a 150 but then i found out it had a blown head gasket issue
Old Jan 3, 2011 | 02:54 PM
tittan1500's Avatar
what plugs are you running?
Old Jan 3, 2011 | 03:07 PM
ATVracr's Avatar
Maybe the head gasket wasnt installed right to begin with?
Something isnt right thats for sure and its not the stock bolts that caused it. IMO.
Old Jan 3, 2011 | 03:13 PM
Sounds like you already had an issue before you started spraying it.
Old Jan 3, 2011 | 06:04 PM
Cold Zero's Avatar
did you reused those head bolts in building this engine ???
Old Jan 4, 2011 | 01:05 PM
im running an ngk tr6
im thinking that i mightve just had a bad gasket from the start it is just a tiny little hole in the gasket.
and no i bought new head bolts when the motor was put together
Old Jan 4, 2011 | 01:40 PM
ATVracr's Avatar
Of course you are
Old Jan 4, 2011 | 02:32 PM
minytrker's Avatar
Did you get the 243's trued before putting them on? I am with everyone else, a 100 shot and stock head bolts wasnt the problem.
Old Jan 4, 2011 | 08:46 PM
yes the heads were brand new never on a vehicle.
and the tr6 are what my tunner told me to run and i trust what he says cuz as of this second he has the fastest 2010 camaro in the world, that he built and put together.
Old Jan 4, 2011 | 09:00 PM
ryarbrough's Avatar
Eh.... Projected tip plugs aren't the best for nitrous...
Trust who you will, but plenty of people are stuck on using a TR6 instead of the right plug.
Old Jan 4, 2011 | 09:06 PM
Whats the power adder of this 2010 camaro? If its nitrous I bet he's not running a tr6. Just because it works doesn't mean it correct for your setup.
Old Jan 4, 2011 | 09:12 PM
ATVracr's Avatar
Your joking right?
The guy is a clown and the car is slow.
