stand alone question
Looking for the best/economical fuel pump for a stand alone nitrous fuel system ?? Looking to spray in the 100-200 range.
Thanks....
O, and regulator. Thanks..
I'm using a nitrous outlet single nozzle set up, if that helps(and yes its an EFI system). And I've decided to do a stand alone fuel system for saftey and sanity. With a 150 shot I will exceed my in tank pump limits even with a hotwire/BAP setup. I'm roughly at 550ish at the flywheel so another 150ish will push the pump beyond its limits, is what I've been told. Or there close to it.
So I'm looking for info on a pump and regulator for a stand alone system. Thanks
Thanks....
I always prefer high pressure. I have used a stock mustang fuel pump with great luck. Whatever you can get the cheapest that is OEM is what I would go with. That is not to say aftermarket pumps are not a great option, just so many knockoffs floating around now you can probably get a knockoff walbro now for a buck fiddy LOL
