High Mileage H/C Car
Old Jan 23, 2011 | 07:06 PM
FreakishSpeed's Avatar
Default High Mileage H/C Car
Like title says....
110K mileage 2000 Camaro
Heads and cam (moderate sized cam)
42 Pound Racetronix Fuel Injectors
Tuned
Can I SAFELY through a 100 wet shot?
Stock bottom end LS1
LS6 Intake
Stock Pistons
Absolute Speed hand Ported Heads
Comp Cam Springs
Titanium Retainers
Hardened Pushrods
EPS Cam
Old Jan 23, 2011 | 09:22 PM
krissoto's Avatar
Yes. there are alot of guys spraying 200,000 mile cars. set it up right and you should be able to put many bottles thru it.
Old Jan 23, 2011 | 11:31 PM
TrikeMike's Avatar
Buddy of mine on here sprayed a 75 shot on a stock bottom end 256k mile lq4. I plan on spraying over 100 shot this upcoming season on stock 125k mile ls1 with ls6 heads and texas speed cam.
Old Jan 24, 2011 | 01:39 AM
custm2500's Avatar
Ph.D. in HUBRIS
I sprayed 100 shot on a 239,000 mile LQ4. Just took it apart tonight to sell the bare block and she looke sexy inside.
Old Jan 24, 2011 | 09:57 AM
Alriiiighty!
Umm, Mr. FreakishSpeed will be on the giggle gas once again.
I had a LME built 408 that could handle a 300 Wet Shot ALL DAY LONG. I sprayed a 150 shot on it a few times, and I had a 100 Wet shot on my stock LS1 back in 2001 (well, the CAR was from 2001 lol).
Used NitrousDave stuff. Some real good deals/prices. I havent heard his name around these parts lately. He IS stil in business, correct? I sure hope so. Mr. Dave will be getting a call from me once everything falls into place.
Old Jan 24, 2011 | 12:46 PM
krissoto's Avatar
^^^^^^Nitrous Outlet is a Sponsor on here!!!
http://www.nitrousoutlet.com/
Old Jan 25, 2011 | 03:38 PM
Chris@NitroDaves
Guest
Posts: n/a
With the H/C if you haven't already upgraded the fuel pump then thats the first thing you need to do. Since you already ahve Racetronix injectors then i'd suggest going with the racetronix fuel pump kit which will get you fueling capable of support around 625rwhp. Other than that you can spary the car with a 100hp shot on those miles. If you wanted to make sure you'd be on the ok side you can do a leakdown and compression test on the car.
