stand alone install ?s
Old Feb 4, 2011 | 10:31 AM
SargeZ06's Avatar
Default stand alone install ?s
I'm installing a stand alone and using a Holley blue at 14psi. I have an NX wet kit at 150 shot with fuel coming off the fuel rail using a .38F. What NX jet should I go with when I move it to the holley blue?
Will I need a regulator with that small of pressure pump?
TIA
Sarge
Old Feb 4, 2011 | 10:41 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Hey Sarge,
The best thing to do will be to use a regulator and bring down the pressure to 10 psi then I can get you the jetting for that!
How are you spraying your car?? Nozzle? MAF?
Thanks Clay @NX
Old Feb 4, 2011 | 12:23 PM
JL ws-6's Avatar
Race your car!
I'd go lower then 10 with the fuel pressure. Foggers we run anywhere from 5 to 6 psi, depending on the jet spread.
Lower pressure, means bigger jet, less chance of it getting clogged.
Old Feb 4, 2011 | 12:48 PM
SargeZ06's Avatar
Originally Posted by NitrousExpress
Hey Sarge,
Thanks Clay @NX
Using a shark nozzle. Wet kit, after MAF.
Just checked and the regulator comes with my pump. So I can dial it down to 10.
Old Feb 4, 2011 | 01:09 PM
That is very true!
You can run it at 5 psi as well...
Here is our jetting for a 150 shot:
5psi: 62n/57f
10psi: 62n/46f
Old Feb 4, 2011 | 01:54 PM
SargeZ06's Avatar
That is very true!
5psi: 62n/57f
10psi: 62n/46f
Thanks
Can you get me the numbers for a 175 and 200 shot?
Thanks
Old Feb 4, 2011 | 03:03 PM
We recommend to use 10+ psi on 175 shot and up.
175hp = 73n/52f
200hp = 78n/57f
If you need anything else you know where to find me!
Clay @NX
