High Fuel Psi VS Low fuel Psi
Is one better than the other, I have a standalone, we are running a Big Shot plate under the Accufab 4150 style T/B this year, I can arrange the jetting either way, was wondering if there is a benifit one way or the other.
I like the added pressure, but the low pressure is tried and true. I would worry more about the tune than which system you go with(in other words, either "seems" to be as good as the other
from what i understand with hi pressure a change in jet sizes can dramaticly change the tune, because the psi is so high its a greater change? idk if i said that correctly but with low pressure u can tune by fuel pressure maybe add couple psi to it instead of changing jets, etc.
If you have 60lbs of fuel and take away 1lb it will not have as great off an affect over taking it away from 6lbs.
In all honestly if you have a seperate fuel system for the nitrous and the tune up is close you can make small airfuel changes by adjusting flowing fuel pressure on either set up. Big changes need to be adjusted with fuel jet.
Same rule for either pressure.
Hope my explanation helps.
Dave
