Intake and plate question
Old Feb 18, 2011 | 12:18 AM
Detoxx03's Avatar
Question Intake and plate question
Can a 92mm tb and plate work with a 102mm intake?
Old Feb 18, 2011 | 05:13 PM
Chris@NitroDaves
Guest
Posts: n/a
It wont work at all. The way the fittings exit they are close to hitting intake and leave no clearance to put lines on them. Now if it's a truck plate it will work because the fittings come out the side. I can re-drill a regular car plate and turn it into a truck plate without a problem.
Old Feb 18, 2011 | 08:07 PM
Detoxx03's Avatar
Thanks Chris
Old Feb 19, 2011 | 06:15 AM
Cold06's Avatar
Or just buy mine for 150 shipped lol
Old Feb 25, 2011 | 09:10 PM
Detoxx03's Avatar
I need to revisit this cause I keep getting mixed answers. A couple places have told me it will work but others are saying no. I don't want to buy the intake and then right after need to buy a fuel rail kit, tb, and new plate.
Old Feb 26, 2011 | 07:38 AM
87silverbullet's Avatar
Listen to Chris @Nitrous Outlet. This subject has been discussed before. If you are going to get a 102 intake just get the 102 plate from Nitrous Outlet and a 102 TB. Sell what ever you have that won't work.
I say its not worth it if you already have a full FAST 92 setup. If you are stepping up in cubes then by all means do it.
Old Feb 26, 2011 | 02:09 PM
Detoxx03's Avatar
I have a buyer for the intake already just need to figure out the other details
Old Feb 26, 2011 | 06:45 PM
w3s1c0a5t's Avatar
Spend the coin you would have wrapped up in it in porting. If it is ported, spend the money somewhere else for better gains.
Old Feb 26, 2011 | 07:44 PM
Detoxx03's Avatar
Its already ported
Old Feb 27, 2011 | 08:56 PM
w3s1c0a5t's Avatar
Originally Posted by Detoxx03
Its already ported
If it was mine I would go ahead and spend the coin on something to get larger gains. If your trying to squeeze every drop from the combo, well you do what you have to and deal with the cost for those last few ponies.
If you think you will enjoy having the 102 and knowing you left nothing on the table, well , you already have a good layout for what needs to be done.
The car is already a very nice ride.
Old Feb 28, 2011 | 09:07 PM
Detoxx03's Avatar
I have some plans in the works just needed a definitive answer.
