Need replacement wet nozzle
You will need to take a small torche and apply heat to the nozzle to release the lock tite in order to get the fitting out.
In the future use a wrench on the nozzle fitting while you are using a wrench on the B-nut. Those nozzle fittings in the Shark nozzle break easy.
Call NX and talk to Craig for a replacement fitting.
If you ruin the nozzle getting it out and want a nozzle that will not have the fittings break off so easy I suggest our 1/8 NPT nozzle.
Our nozzle fittings are not as weak because they have more material.
http://www.nitrousoutlet.com/catalog...8&product=2528
Dave
