Safest way to do a 100 shot?
I have an 02 ss ms4 cam ls6 heads all the bolt ons. Stock bottom end. Im about to put an aftermarket high flow fuel pump then i want to run a 100 shot. What all would i need? I want to go all out and to it right. Im going to get a "safe system" is what they called it but is there anything else i would need to be safe?
I would recommend looking at a window/tps switch. You may need to have a couple to 4 degrees of timing pulled depending on the fuel you are using. You will also need to go with a step colder plug @ .032-34.
Our NANO system would help you too. It will give you consistent runs, instant pressure, and be able to use all of the nitrous from your bottle.
Eventually i want to stroke the car and pro-charge it and i will ajust the shot to that. I just want to know what i can do how the motor is now. Ms4 cam ls6 heads stock bottom end. And about the safe system im not sure. I was talking to one of the sponsors i guess a while back and thats what he called it. He said they have a "safe system" thats about $300 i can bolt on and its for the nitrous. That is as specific as i can get. Thats what he said the name of it was. Safe system
What are your future plans with the car?
There are quite a few options for your application. When you say you are getting a "safe system" can you be alittle more specific? I assume you are talking about the marketing of a certain brands but would like to clarify.
Dave
Dave
Its was a guy from nitrousexpress i was talking to about the safe system
