A few questions
Old Feb 23, 2011 | 02:37 PM
lilmiller74's Avatar
Default A few questions
What type of power are the stock rod bolts capable of, and should I be worried about them with a h/c+150 shot? And I already have my window switch so what is the device I need for retarding the timing?
Old Feb 23, 2011 | 06:52 PM
Carter01's Avatar
Has allot to do with the tune, if you can keep the motor happy they can handle allot. Cam, myself and many more spray 250 or greater on stock rod bolts.
Old Feb 23, 2011 | 10:03 PM
Thanks man. Anything else guys
Old Feb 23, 2011 | 10:21 PM
dnkynrbk's Avatar
150 Shot you are ok with rod bolts. Like stated about the right tune, Run non proj. plug NGK a #7 or #8s to be safe. How is your fuel injectors duty cycle? or did you allready buy aftermarket inj.
Old Feb 23, 2011 | 10:34 PM
Im about to pick up 42# injectors tomorrow, and my race tronix fuel pump and hot wire kit is on its way.
Old Feb 24, 2011 | 03:52 PM
jbrenner0188's Avatar
yea i have been sprayin mine for three years at 150 on stock bottom end and had no trouble..
