50 dry shot..
Thinkin bout doin the 50 dry, on my c5 vette do i need to leave mass air screen in to ensure proper readings with the 50 shot,an also what plugs?ngk,or autolite 103s? an what poistion does nozzle need to b in thanks...
Guest
Posts: n/a
I prefer NGK plugs. Part of this is just the relationship I have with those guys, also there customer service is amazing.
Ngk plugs are also very easy to read for working on the tuneup. I have a guy I work with a lot NGK. If you have any plug questions that I cant answer he is the guy to talk to. Shoot me any questions In a pm and I will forward his contact info to you if you need it.
We carry NGK in stock as well.
http://www.nitrousoutlet.com/catalog...26§ion=101
As far as nozzle placement. You want to make sure its very secure and has at least 2 inches from the maf. Dry nozzles can be a bear if you do have experience with them. Our Fbody Halo ring makes it much easier on them but on the c5 application nozzle placement is key. You will want to make sure even on the small shot that you pull EVERY plug for a few passes to ensure you are not getting nozzle movement causing a difference in distribution from run to run.
If you would like to talk more in depth or need some products feel free to Pm or Email me sir. I try and be quick to respond to tech questions.
Graham @ N20
Graham @ N20
