what to do
Old Feb 28, 2011 | 08:54 PM
rob00ss's Avatar
Default what to do
im hooking up nitrous but not sure if ill even us it but once or twice. Do i need to change plugs and get tuned for it. It will be a 75 wet shot
Old Feb 28, 2011 | 08:57 PM
rob00ss's Avatar
it will be a dry whot not wet im sorry
Old Feb 28, 2011 | 09:00 PM
T AM's Avatar
Why not? It's cheaper than building a new motor. Doesn't seem worth the hassle of installing if you honestly are only going to use it once or twice. If you do get it, get a device that will let you run full timing n/a and pull timing when on the bottle.
Old Feb 28, 2011 | 11:25 PM
dnkynrbk's Avatar
I would change the plugs and run a NGK #7 when you spray it. If you are going to do it do it right.
What kit are you going to use?
Old Mar 1, 2011 | 11:42 AM
rob00ss's Avatar
Its just a universal Nos kit that I traded some parts for and car is a H/C/I car so I don't want to go to high in horsepower for the stock bottom end
Old Mar 1, 2011 | 11:46 AM
Graham@NitrousOutlet
Guest
Posts: n/a
I would tend to agree, don't spray if your not willing to make it safe.
Now if you are just needing some parts and information to make sure you are safe that is something we can certainly help with. No reason to hurt the motor over a few passes. Were here if you need a hand.
Old Mar 1, 2011 | 09:02 PM
rob00ss's Avatar
Yea Graham I will prolly be giving u a call I would like some info
Old Mar 1, 2011 | 09:51 PM
LS2Z28monster's Avatar
ok................
Old Mar 1, 2011 | 10:53 PM
Guest
Posts: n/a
Ya why not sir? Even if you got it all under control were happy to put another set of eyes and just double check everything.
Give me a shout when you got some time.
Graham @ N20
Old Mar 1, 2011 | 11:21 PM
dnkynrbk's Avatar
Graham @ N20
+ 1 for the Team at Nitrous Outlet they have helped me out many times.
