Plate systems?
What are the future plans on the car? Any plans for big cubes or a forged bottom end?
The carb style intakes on ls1 cars are not an easy intake to set a plate on and just go. They do need to be test fired and distribution checked before you pill it and let it eat on the car. I would also make sure I pulled EVERY plug on several runs to make sure that the distribution is good before adding jet and moving along in the tune up. This is not a bias toward anyone as they ALL need to be checked in my opinion.
Many plates also have a hang over and do not match the flange surface as well as I would like so they cut into the intake path some.
If you have the option of send us your intake, we are big on doing custom matched spray bars to the intake. This allows us to get the distribution right on YOUR car. This is very good solution for a lot of applications based on the added hood clearance and easy access to the fittings for jet changes. This also opens the option of swapping out any spacer ( Either thickness or possible a HVH style spacer) you choose for your combination.
Here is a some examples to check out:
http://www.nitrousoutlet.com/installs/install.asp?id=17
Anyway, they said they started to see distribution problems right around my nitrous level. They said something about devoting some energy to creating their own carb plate, but it seems like they've kept their efforts to the spray bars.
All of that being said, I'll probably ship my intake to them before long to have them work their magic on it. Just understand that the Zex plate CAN work. It's obviously not the best option (no plate is) but if you watch what it's doing you can get good results.
You always up the jets and then you will want the spray bars.
Thanks for adding your experience ryarbrough. Did you ever test fire the plate through the intake previous to putting on the car?
Graham @ N20
If the car still needs more oomph, I'll do something else with the intake.
Glad to see some posting of ACTUAL results from a knowledgeable guy.
Graham @ N20
If you will need other components I ship them back with the intake. ( fittings, jets, pressure gauge)
If you would like to give me a call with any more questions im happy to go over the setup and pro's and con's with you.
Graham @ N20
Did I mention simple?
Graham @ N20
