TNT throttle body solenoid bracket.. Help
Ok guys… I have looked around on EBay and looked in the classified sections for this plate and have had no luck. I even looked on Nitrous Dave’s web site. I need this bracket does anyone know where I can buy this.
TNT throttle body solenoid bracket. I will post a picture of a member’s bracket that has it.
![](https://ls1tech.com/forums/attachments/texas-classifieds/283503d1299525709-sale-afr-tnt-arp-mti-air-lid-ws6-002.jpg)
How I have it run right now![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![](https://ls1tech.com/forums/attachments/texas-classifieds/283502d1299525709-sale-afr-tnt-arp-mti-air-lid-ws6-001.jpg)
u wont be able to find it new or used, and if u do good luck man since tnt aint around, i have their f2 i just put on, order a bracket from hsw their throlle body bracket itsthe same design is the tnt one. well mine atleast...
Guest
Posts: n/a
How about using our brackets to mount them where they are in our hardline systems, and then place Y's right above the throttle bodys to run to the nozzles. I think with correct hose length I can help really clean it up.
If you don't think this will provide the look you want let me know. Ill keep brainstorming for you sir.
Graham @ N20
Graham @ N20
Graham @ N20
Graham @ N20
Guest
Posts: n/a
http://www.nitrousoutlet.com/gallery/photo.asp?id=388
These mounts with soft lines and a "Y" around the throttle body area to each nozzle.
Graham @ N20
Graham @ N20
Graham @ N20
Graham @ N20
Anyway I can get hardlines made for my system?
Guest
Posts: n/a
We can use the brackets from that picture and then do the routing of SOFT line as I mentioned earlier.
Graham @ N20
