nitrous and ngk tr6???
Old Mar 12, 2011 | 03:50 PM
Footlead's Avatar
Default Br7ef
Yeah===What Frozen WS6 said!
Old Mar 12, 2011 | 10:27 PM
ATVracr's Avatar
Originally Posted by Frozen WS6
Read this article.
http://www.ngksparkplugs.com/docs/te...de_Affects.pdf
My black car went a best of 10.00 on the 100 shot with 6's. I found this from NGK saying to go one heat range colder for every additional 75hp of spray. With the only change being made, I put in the br7ef. My 100 shot went a new best of 9.89 in the quarter.
tr6 are good up to 75hp shot
br7ef are good up to a 150 shot
Read it again .... Doesn't say anything about a tr6 being ok to use. It says 1 step colder, projected tip plugs should not be used with nitrous.
So br6 or br7 is what you guys with 100 shots should be using.
Old Mar 12, 2011 | 11:26 PM
Frozen WS6's Avatar
Thanks for the correction. I miss typed.
I actually originally learned that from you guys. Then found the article. Our local supposed ls expert is the one that swore tr6's were ok up to a 150 shot. Then wanted to argue with me when I told him he needed to go check again. That's why he's never and will never touch my cars.
Old Mar 13, 2011 | 05:32 PM
02ls1ss's Avatar
it's all in the tune, i run tr6's with 150 shot not a problem at all.
Old Mar 13, 2011 | 08:28 PM
dnkynrbk's Avatar
What is your timing set at.
Old Mar 14, 2011 | 06:24 PM
ATVracr's Avatar
I can make one live on a 300shot tr55's and 87octane , doesnt mean you should.
If you (or what ever dummy tuned it) knew how to tune you wouldnt use a tr6.
Old Mar 15, 2011 | 04:52 PM
BayRunnerWS6's Avatar
I just switched back to tr6's from br7's on 100 shot.
Old Mar 15, 2011 | 05:02 PM
dodson55's Avatar
I run tr6 with a 125 and it has worked fine so far
Old Mar 15, 2011 | 10:22 PM
a4ls2goat's Avatar
listen to ATVracr, he knows what hes saying...
well atleast i will
Old Mar 16, 2011 | 02:27 AM
camscam02's Avatar
hahahaha, you have much to learn.
Just because it lives, doesn't means it's ok.
Old Mar 16, 2011 | 04:10 AM
itsslow98's Avatar
TR6s on 100 here, and ran TR6s on 100-150 on my SS as did the previous owner for 30k miles.
DOnt jump on the bandwagon cause some people tell you to. TR6 have proven themselves plenty.
Old Mar 16, 2011 | 08:05 AM
  #32
ATVracr's Avatar
AGAIN ....My uncles cousins sisters fathers brother sprayed a 500 shot on tr6's all the time with no problem so they must be ok.
Not a bandwagon thing at all its evolution.
500 years ago people thought the world was flat.
10 years ago people thought a rich nitrous tune was safe.
2 years ago people thought TR6's were ok to use with nitrous.
Imagine what you will know tomorrow.
Old Mar 16, 2011 | 06:42 PM
  #33
1994z's Avatar
aaahhhhh so true..
Old Mar 16, 2011 | 07:10 PM
  #34
lol that's hella funny. good call, sir.
Old Mar 18, 2011 | 11:45 AM
  #35
kinglt-1's Avatar
atv know his ****...listen to what he preaches!
Old Mar 18, 2011 | 02:52 PM
  #36
dannyz's Avatar
Then why are we not hearing of people hurting their engines on tr6 plugs with smaller shots?
28 bottles of nitrous threw my car, 71,000 miles, and everytime I swap my plugs, they still look like they could go another 5,000 miles.
You guy's having nothing to back your claims other then heresay.
If your tune is on you ARE NOT going to do any damage whatsoever, [ including excess wear and tear ] to your engine on smaller shots.
If your burning a ground stap on a 100 shot with tr6 plugs, something is off in your setup.
Old Mar 18, 2011 | 03:04 PM
  #37
Graham@NitrousOutlet
Guest
Posts: n/a
People do. This is not hearsay. As ATV stated earlier, its not that you CANT get it to live with Tr6, its that there is simply a better option and NO reason to not run a better plug on the car.
I am not trying to start an argument. But its not like the correct plug cost more money, why try to make something work when the correct part is just as easy to get and safer?
Graham @ N20
Old Mar 18, 2011 | 03:18 PM
  #38
ATVracr's Avatar
Simple, its hard to hurt a LS1 with a 75 shot no matter how BAD the tune is.
The difference is the people doing it right go alot fast than 11.65 @ 118 with a cam only nitrous car.
If I put the right plugs and correct tune in your car it would go 1/2 second faster and NOT HURT ANY PARTS.... lets see you do the same with TR6's.
Seems to me the only dummies that want to argue this fact is the ones who have TR6's and dont want to change them. Who do you think has a better understanding of nitrous, spark plugs and what a nitrous engine wants a guy who sprays a 75 shot or Mike Thermos? Google that name.
It is hard sometimes to try and come in here and help people.
Old Mar 18, 2011 | 03:45 PM
  #39
dannyz's Avatar
So you grudingly admit that with a smaller shot tr6 plugs are fine?
Old Mar 18, 2011 | 04:15 PM
  #40
camscam02's Avatar
Graham @ N20
THIS!!! End of story. I don't see why some people cant understand this
