nitrous and ngk tr6???
Old Mar 8, 2011 | 04:00 PM
badazz99ss's Avatar
Default nitrous and ngk tr6???
will i be ok with ngk tr6 plugs spraying a 100 shot. I just put them in yesterday my car is getting tuned thursday.
Old Mar 8, 2011 | 04:32 PM
Steve-O-08's Avatar
Running TR6's on my truck with a 75 shot on stock timing. Should be fine on a 100 shot.
Old Mar 8, 2011 | 05:14 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Should be good to go there! I'd gap them about .035-.040"!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Mar 9, 2011 | 07:14 AM
dnkynrbk's Avatar
I would run a TR7 throw the TR6s away. You need the BR7EF
Old Mar 9, 2011 | 09:10 PM
badazz99ss's Avatar
Thanks guys well im going to gap the tr6's .35. Ive heard that if they came with the brown cardboard covers on the end that they were already gapped.
Old Mar 9, 2011 | 10:08 PM
Graham@NitrousOutlet
Guest
Posts: n/a
No reason not to double check gaps on plugs. Doesn't take much to have one off. It takes very little time so always verify the gap. Might save you some expensive parts.
Graham @ N20
Old Mar 9, 2011 | 11:20 PM
badazz99ss's Avatar
Ok thanks man that makes sense i will ****** them back out and gap them. Better safe than sorry. Ive always wanted to know the reason for a plug to be gapped???
Old Mar 10, 2011 | 07:21 AM
ATVracr's Avatar
What is done to the car? is it stock?
https://ls1tech.com/forums/nitrous-o...tip-plugs.html
Old Mar 10, 2011 | 07:53 AM
O.N.'s Avatar
is this the same gap guys are running for N/A without nos?
Old Mar 10, 2011 | 09:57 AM
lttransam's Avatar
this was mine on a 100 shot.. these plugs seen alot of spray though..
Old Mar 10, 2011 | 11:44 AM
Guest
Posts: n/a
This tune had to have been radically far off for a 100hp worth of nitrous to burn off a strap. Have you taken a look at the entire tune? I would not spray again if you have not.
Graham @ N20
Old Mar 10, 2011 | 11:58 AM
Z284U2TRY's Avatar
I use to lean on tr6's hard back in the day and never lost a strap on one. Circa 99-00 hundreds if not thousands of guys used that plug with 150 hits on stock tunes.
Old Mar 10, 2011 | 12:48 PM
ATVracr's Avatar
My uncles cousins sisters fathers brother sprayed a 500 shot on tr55's all the time with no problem.
The link I posted was written by Mike Thermos no one in this thread or on this site has more knowledge about nitrous then him. Now if you still want to use projected tip plugs for your nitrous motor then well your just dumb.
Old Mar 10, 2011 | 01:06 PM
Guest
Posts: n/a
Not what I said... But close to what I was trying to get across.
Here is a sound bite:
Plugs a cheap, motors are not.
Graham @ N20
Old Mar 10, 2011 | 06:25 PM
Footlead's Avatar
Default Plugs
Put the BR7EF plug in it. This plug is Non-projected tip. The TR6s are projected tip as u see in those pics. I used to run the TR6s but went with BR7Ef and it runs great with a non projected tip which on the spray can keep the blow torch from melting or damaging a piston. Runs just as good with the cooler plug and have a little piece of mind when you are spraying it. IMO !
Old Mar 10, 2011 | 06:28 PM
1nasty86's Avatar
Turd Gen Guy
i just switched from a tr6 to a br6. i dont plan on going over a 125 shot so i think the br6 plug will work well for me because i drive this car alot.
Old Mar 11, 2011 | 11:33 AM
badazz99ss's Avatar
well I think im going to run the br7's what should i gap them to???
Old Mar 11, 2011 | 11:54 AM
Guest
Posts: n/a
.36-.33 sir. I would go ahead and gap them at .35.
Graham @ n20
Old Mar 11, 2011 | 02:54 PM
ThreeHonks's Avatar
Graham @ N20
he did and cracked 3 valve seats
Old Mar 12, 2011 | 01:03 PM
Frozen WS6's Avatar
Read this article.
http://www.ngksparkplugs.com/docs/te...de_Affects.pdf
My black car went a best of 10.00 on the 100 shot with 6's. I found this from NGK saying to go one heat range colder for every additional 75hp of spray. With the only change being made, I put in the br7ef. My 100 shot went a new best of 9.89 in the quarter.
tr6 are good up to 75hp shot
br7ef are good up to a 150 shot
