need help with jets and stand-alone system
Old Mar 9, 2011 | 09:38 PM
aarontracy's Avatar
Default need help with jets and stand-alone system
I have an 02 Z06 im running a EFI Vic JR, with a direct port I pieced together. Need help determining what jets I will need for 150,200,250 shots
Im using 2 NOS 16040 Pro-shots and 2 NOS 16050 Fuel Cheaters, those are plumbed into a set of Nitrous Express Directport rails, and Im using NOS foggers not sure what # but its the black 90 degrees with bronze fittings.
I already bought a 1 gallon cell for my dedicated fuel source but what external pump and regulator should I go with?
Old Mar 9, 2011 | 10:07 PM
Graham@NitrousOutlet
Guest
Posts: n/a
You can not have accurate jetting until you decide what fuel pressure you are going to run.
If you are still working on a stand alone, you can buy the components we use in our stand alones. They are what I would recommend. We can also make sure you have the correct length hoses and fittings.
Get with me tomorrow if you have time and I can get you the product you need sir.
Graham @ N20
