FJO TPS Programming Issues
Old Mar 17, 2011 | 10:29 PM
zlthomps's Avatar
Default FJO TPS Programming Issues
I've been reading about needing to adjust the TPS signal to a falling signal, but in the interface I dont have this as an option. Any ideas? I went through the "TPS Learn Process" but according to the manual, the green light should be on at idle and WOT, and right now its only on at WOT. Any ideas? I attached a picture of what my interface looks like right now...
Old Mar 17, 2011 | 10:59 PM
camscam02's Avatar
I'm pretty sure it should only be on at wot. It was a very simple process
Old Mar 18, 2011 | 01:20 AM
zlthomps's Avatar
Hrrm, weird. I tried to update the firmware, and then it wouldnt come on at all, sigh. Rolled the firmware back, and then it turned on again.
Old Mar 18, 2011 | 01:48 PM
zlthomps's Avatar
I totally misread the manual, you are right. The light should only be on at WOT, which means everything is working.
Old Mar 18, 2011 | 02:09 PM
camscam02's Avatar
Haha no worries. I havnt read it in awhile but I was pretty sure I was right. Glad you got it figured out.
