2 bottles...pressure drop?
Do you spray the car on the street at all? Do you trailer your car to the track?
Graham @ N20
Graham @ N20
what psi do you start with?
i have the nitrous outlet 90mm plate. jetted for a 250 currently.
Your adding a decent amount of product. If you want an idea of what your looking at, PM your email. I can send you a quote on what all you would need to do a heated dual bottle setup.
I like the NANO for a street car tho. Especially for the size shot your running.
Would two 10# bottles, each with a NANO system last you long enough to make it worth it? One NANO system is about what the heaters would cost you. That would be a lot of usage before needing refill.
You have a few options.
i know i will give up a little power but if i can keep the pressures up it will still be plenty fast.
thanks
dicky
thanks
dicky
This is another fellow member of the boards.
If Brad can not help you find someone closer to fill, Talk to him about filling your own bottle. Brad can set you up with what you need to gravity feed.
I had a customer fly me to Florida to tune his car last month. He was gravity feeding his own bottle at the track. It can not fill the nano bottle all the way but it was getting the job done.
To answer the question on dual bottles. The dual bottles will take care of the pressure drop for the most part. Its not as rock solid across the curve like the nano though. And the nano does increase flow across the jet compared to no nano so your tune up will change. You will also loose the luxery of instant bottle pressure on demand.
We run dual bottles in our race cars. But we have a hotbox to soak the bottles in embetween runs. Then we have heaters in the car incase we get stuck in the staging lanes. We run our pressure at 950 psi so the pressure drop will not be as bad. We MIGHT see a drop of about 50 to 75psi on a 400 shot.
Dave
