Update: Put some power down!
Old Apr 7, 2011 | 03:11 PM
Gaunt's Avatar
Originally Posted by kinglt-1
Gaunt, wheres your temp sticker on the bottle? That would of told you its too hot to use the nano system.
Honestly, that temperature sticker slipped my mind, I was more focused on the pressure gauge.
This picture shows where the needle was approximately. It's an in-line gauge that is just after about 4 inches of nitrous line, right before my nitrous filter.
I was getting close to the "red", but still in the "green" portion.
So I take back saying it was above 1100 psi, it was very very very close to the 1100 psi mark.
At any rate, no harm done, and I'm not sad that I have a Nitrous outlet kit with a NANO system in my car.
I will be putting down some numbers this Saturday, so I will keep you all updated. Made 368 rwhp unlocked through the 9 inch, so we will see what it makes on the spray
Old Apr 7, 2011 | 03:22 PM
Brad@NANO Direct's Avatar
Nitrous Outlet and NANO products have always been a good pair
Like Dave said if need be we can adjust the regulator down if we need to. Just let me know and i'll give you the address to send it to for the adjustments.
Old Apr 7, 2011 | 09:12 PM
Nitro Dave's Nitrous Outlet's Avatar
Originally Posted by Brad@NANO Direct
Dave,
Gaunt stated that the bottle was in 90 deg sun and 1100psi before opening the NANO bottle. The NANO did not pressurize it to 1100psi. I am sure his NANO bottle regulator will be in range with your solenoid to function properly.
Sorry, I should have read closer. If the bottle is over heated, Nano or no Nano its going to have to be purged down or cooled. Unfortintly purging pressure down with the Nano is pretty hard to do.
Old Apr 9, 2011 | 12:23 PM
Gaunt's Avatar
Alrighty, put down some numbers.
First pull was just an N/A pull (383/378)
Second pull was with the dual cutouts open (396/393)
Third pull was Nitrous spraying, cutouts closed (514/501)
Nitrous pressure was a constant 900 psi the whole run. My Nitrous pull got cut off on the dyno print out for some reason (I forgot why, tach signal maybe).
Mods:
LQ9 with Predator Z 230/228 .592/.588 110-1 LSA cam
Stock Heads
LS6 intake
Full exhaust with dual DMH cutouts at the headers
Moser 9 inch with WaveTrac
Mildly built 4L60E from local shop (Top Gear motorsports), 3600 stall
Nitrous Outlet 10lb kit with window switch, etc.
NANO 3000 kit
Old Apr 9, 2011 | 02:32 PM
Gaunt's Avatar
Also going to change from TR6s to a BR7-EFS per recommendation from my tuner
Old Apr 9, 2011 | 03:01 PM
StormesRacing001's Avatar
Very Nice numbers! Im sorry if it was already mentioned but, how big of a shot were you spraying?
Old Apr 9, 2011 | 03:06 PM
Gaunt's Avatar
Thank you , and just a 150 shot right now.
Old Apr 9, 2011 | 03:09 PM
I have a Nitrous Outlet Plate kit to put on my car after the H/C swap and I hope I can get numbers like that.
Old Apr 9, 2011 | 03:42 PM
Detoxx03's Avatar
Pretty solid numbers. Yes please change plugs
Old Apr 11, 2011 | 08:10 AM
Gaunt: Glad you got it ironed out. Now time for some track numbers.
Old Apr 12, 2011 | 05:23 PM
Chris@NitroDaves
Guest
Posts: n/a
I second this...
Old Apr 24, 2011 | 11:40 PM
  #32
jdm-andy's Avatar
Nice numbers man!
When are we gonna run?
