Need help!!! My nitrous system doesnt work!!!!
Old Apr 4, 2011 | 10:57 AM
slp1300's Avatar
Default Need help!!! My nitrous system doesnt work!!!!
Hi i have a nitrous plate system form nx in my carbed 6.0, the fuel jet is 41 and the nitrous one is 57 for a 100hp shot, the thing is that when i go full throttle and the system armed i dont see any diferrence, any advice?? Thanks
Old Apr 4, 2011 | 11:36 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Hey man!
OK, first things first. Have you tested your system without running the car? Do the solenoids "click"?
What type of electrical components do you have? Progressive? Window Switch? FPSS?
Give us a layout of whats going on and we can help get you lined out!
Clay @NX
Old Apr 4, 2011 | 11:56 AM
slp1300's Avatar
hey thanks Clay for your quick answer i really dont know what kind of system i do have but let me tell you about it, both solenoids do click when the system is armed, the system will activate al wot, one thing i have noticed is that the at wot i can see the fuel solenoid inject fuel, and i dont see no nitrous, i bought this system used, should i check the nitrous soleinod (DISASSEMBLE FOR CLEANING). Thanks for your help
Old Apr 4, 2011 | 01:56 PM
You may have a defective solenoid, or even bad wiring... but being that the solenoids are fairly old, I would suggest having them serviced just to be on the safe side.
Check and double check your wiring.
http://www.nitrousexpress.com/Instructions/stage1.pdf
Here is our instructions/wiring diagram to help you look over the install.
Let me know if you need anything else or if you need me to go through your solenoids we will be happy to help you out.
Clay @NX
Old Apr 5, 2011 | 10:01 PM
5.7mmImportkilla's Avatar
If it armed and not spraying check your rpm trigger wiring? And prob check if your relay wiring are correct...??
Just a thought..?
Old Apr 5, 2011 | 10:19 PM
dnkynrbk's Avatar
What activation kit are you runing?
Old Apr 6, 2011 | 12:35 PM
slp1300's Avatar
actually im not running any relay, is it very important to have one? because the guy that installed the kit told my that it wasnt very important, but since this is my first nitrous kit i dont really know
Old Apr 17, 2011 | 02:55 PM
slp1300's Avatar
i activate it via WOT
