fuel pressure safety switch
Old Apr 6, 2011 | 02:46 PM
97' Formula's Avatar
Default fuel pressure safety switch
ok i got a NX FPSS and i was wondering where is the best place of connecting to the threaded part of the piece. Thanks
Old Apr 6, 2011 | 03:57 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
I would use a manifold to thread it into and run it inline with your fuel line.
http://www.nitrousexpress.com/produc...ils.php?id=227
This will allow you a port to thread it into with your fuel source.
If you need anything else let me know and i will help you out!
Old Apr 6, 2011 | 04:24 PM
slow2500's Avatar
The trash.
Old Apr 6, 2011 | 04:54 PM
Thanks for the help...i have one of those in my kit. another question would you put it before your fuel noid or after?
Old Apr 6, 2011 | 05:16 PM
It will go inline between your fuel source and your fuel solenoid.
Old Apr 6, 2011 | 05:21 PM
ok cool thats what i was thinking thanks for the help....is there anyway i can contact you? i was needing to ask another question can i call that number listed in you sig? didn't know if u had a special extension or what
Old Apr 7, 2011 | 09:29 AM
Yes sir, You can call that number or (940)767-7694.
Old Apr 7, 2011 | 09:35 PM
Nitro Dave's Nitrous Outlet's Avatar
Since you have an LT1 do it this way. After you remove the shrader valve stem you will connect the manifold to the shrader valve.. The blue fitting in there picture is the manifold. The female end will screw on the the fuel shrader valve at the back of the intake. The hose that feeds the fuel solenoid will screw onto the male end of the manifold. The FPSS will screw into the 1/8npt port.
Odds are the line will loop up and rub against the cowl over hanging the engine. If you want to clean that up alittle you will need a 4 an swivel 90. We carry them if you can not find one.
Hope this helps..
Dave
Old Apr 8, 2011 | 09:16 AM
thanks for the advice but i got an ls1 car the name is from an old car like 5 yrs ago. i got an ls1 now.
Old Apr 8, 2011 | 09:47 AM
It was good speaking with you yesterday, if you need anything else be sure and let me know!
Clay @NX
Old Apr 8, 2011 | 12:14 PM
LOL, Makes since.. The screen name got me.
