NOS not kicking on?
Old Apr 9, 2011 | 12:29 PM
-fidanza-'s Avatar
Default NOS not kicking on?
Hey guys, I have a 98 Vert and have sprayed it before. I did some bolt on's and had it tuned by frost and last night had my bottle filled. I tried spraying it and it was bogging down and oil pressure was raising like crazy so turned it off... It's a ZEX 125 wet kit
Old Apr 9, 2011 | 12:39 PM
Graham@NitrousOutlet
Guest
Posts: n/a
Oil pressure was rising like crazy?
What plugs? What was the bottle pressure? Did frost know you were spraying it?
Old Apr 9, 2011 | 01:29 PM
-fidanza-'s Avatar
Oil pressure guage was almost pinned, he knows I was spraying it but I have to get a switch that pulls timing out 4 degrees that he has. I have NGK T55 Plugs in it and no bottle pressure guage.
Old Apr 9, 2011 | 01:46 PM
zracer323's Avatar
So you are spraying a 125 shot without pulling any timing, on plugs that are too hot and you have no idea what your bottle pressure is? Its no wonder you are having problems. You may want to fix all those things first and see if that helps.
Old Apr 9, 2011 | 01:52 PM
-fidanza-'s Avatar
I have a 50 pill in there now.
Old Apr 9, 2011 | 02:46 PM
1998flamedCamaro's Avatar
Read the stickies on here and any other information you can find before you cause damage to your engine. You are NOT ready to spray nitrous on your car.
