does anyone have a electric diagram on switches this is for my bottle heater and bottle opener and purge or is it even possible??
everything is removed heater core/ac,fog lights,abs
You hold the button till the line opens then let off. I have my line run in the car, and you can here the line charge, call nitro daves they have the ash tray kits that are very clean.
It would eliminate the hassle that you are going thur. I still dont think the fog light switch would work either you could use it for the master arming switch. Depending on how may amps it would draw thur the switch.
