Where to get a Dedicated Fuel Cell for C5 (2002 Z06)
Anyone know of a place to buy a fuel cell for dedicated nitrous use in a C5?
I'm looking for a kit that has a dedicated pump and regulator.
http://www.nitrousoutlet.com/catalog...3&product=1000
Ls1tech & Truck Sponsor
Here is our SAFE Tank... It will easily mount in the battery tray of your vette.
It includes a high output internal pump with an external adjustable regulator.
Here is the details. If you have any further questions feel free to shoot me a PM!
http://www.nitrousexpress.com/produc...ls.php?id=1488
Clay @NX
Clay @NX
Guest
Posts: n/a
Our Dedicated fuel system will ACTUALLY fit in the battery tray on your corvette:
![](http://www.nitrousoutlet.com/images/products/00-12013.jpg)
http://www.nitrousoutlet.com/catalog...3&product=2864
We mounted the regulator so that it would fit perfectly with no modifications at all. It is a aluminum tank that has an external Aeromotive regulator with a High and low pressure spring. This allows you to bolt in the tank and use the same jetting that came with your system, or if you have the correct jetting, switch to lower pressure if you wish. This system is complete and could not be easier to install. As always, if you have any problems, you get a hold of us anytime.
![](http://www.nitrousoutlet.com/images/products/00-12003.jpg)
This is the same internal pump and regulator, but housed in a tank that will bolt by your intake on the passenger side. This again does require any relocation or modification. Both will handle more nitrous than you will ever care to spray, around 800hp worth.
There is a lot going on with a dedicated fuel system. The install is actually pretty simple however. Few turns of a wrench and some simple wiring.
Thanks for the info.
I had ordered this from a speed shop about a month ago but since it hasn't arrived was poking around to see what else was avail.
http://www.nitrousoutlet.com/images/...s/00-12003.jpg
This looks like the way I will go. I don't really want the battery moved and don't care for the fuel tank that close to the headers.
I'll probably go to a max of 200hp wet shot.
NX Express. Do you make a system like this also or strictly a batter located tank?
Guest
Posts: n/a
