Cam question for N2o?
Question is, what cam spec should I go with?
I was thinking something in the 240's/250's range with about 640's lift on a 111 or 112?
Also it's going to bored .030 over with a -4 dish maybe?
Any info would be awesome!
Thanks.
While you are at it you might want to cut the heads. They have big chambers and cutting them will help bump the compression if you are going to go with that much cam.
If it were me, I would cut the heads and put an MS3 in it and then spray it.
He also has AFR heads compared to you trying to use 317 heads. If all you are looking for is a choppy idle get an MS3 or 4 or get a Trex and be done.Call Geoff at EPS or get in touch with PatrickG on here and get them to spec you something. Since you have a 6 spd you do realize you will need no less than 4.30 gears to run a cam like that?
Why would I need no less then 4.30's?
Yeah I was thinking 112 would be too much lol..
And this is all in the works right now. I'm not really saying that's what I'm going to get
Thanks for all the input.
Also I don't want a off the shelf cam I want a custom one. Don't you think that would be better?
Those are some good numbers man
You will need 430 gears because the car will have no bottom end grunt to get the car off the line plus you need to keep a big cam in its powerband and using deep gears is what will keep it there. If you still have the ten bolt then you need to scrap all this and get you a rear. Unless, you plan on keeping street tires on this car.
http://www.youtube.com/watch?v=KjcwvqAQRZw
It will be track/street and probably my DD for a little while.
Thanks for the input guys
