Timing with Race Gas
I sprayed the Silverado for the first time this Saturday and want to be safe when I start increasing the shot. I started on a 50 shot but want to go as high as 200.
If I am running 91 oct gas on say a 100 shot with 4 degrees pulled would I still have to pull that timing if I used race(100, 109, C16 etc.) gas?
BTW, the 50 shot dropped my times 1/2 second. I did not have a wideband and I did not pull the plugs because it was just a 50 shot.
I have both HPT and EFI Live and currently I am using EFI to reflash the PCM to pull timing but I am going to reflash it using one of there COS so I can pulltiming on the fly by activating the nitrous.
It gets tedious having to flash when you want to spray and I don't want to use the resister trick. I sprayed it for the first time this past Saturday and will be upping the spray slowly and then install the COS.
