Big nitrous back fire=bent valve, Need HELP
I had a nitrous back fire out racing the other night,it happened right before the end of the quarter,am i running my fuelrail and fuel line dry ? It busted the air filter and bent a intake valve on #1 cylinder,that sparkplug was messed up and #5 plug,Any help would be good,i may have had a little much timing after 3600 rpm its 22-23 degrees,im using a .083 nitrous jet,a little about my setup
1999 Silverado 2wd ECSB
LQ9 6.0
Ported L92 heads
ARP rod bolts,stock shortblock
L92 intake,fast 90mm throttle body
headers,3"y-pipe,single 3"muffler and tailpipe
Comp cam 581/598,224/234,112
3800 fti converter,built 4L60
3.73 gears
Single Walbro 340 fuel pump in tank
All stock fuel line,L92 fuelrail
with 99 corvette fuel filter that hooks to fuelrail and stock feed and return line,and i also have the factory inline filter
93 octane
What caused this
Any help THANKS
I think you don't have enough octane for that power level with a stock motor IMO... alot of people get away with that, but I wouldn't do it myself.
LQ9 6.0
Ported L92 heads
3.73 gears
93 octane
What caused this
Any help THANKS
There is no telling until we get a little more communication going sir.
I'm sure, that there's more then just a valve bent. I bet if you pull the heads and look at the pistons, you will see something that's not too pretty.
Maybe not if he's lucky... but something is telling me that won't be the case.
Only confirmation I need that the motor has big problems, is what plugs were in it. if I hear anything more then a #8 heat range the motor's probably toast.
Make sure you do a compression test.
That plug should be o.k, but I like to run the ngk when anything is first getting set up, they have alot weaker ground strap and show heat alot quicker/easier then autolite plugs do....
General rule, is if you melt an autolite plug you definitely hurt something.
LQ9 6.0
Ported L92 heads
3.73 gears
93 octane
What caused this
Any help THANKS
This is the guy you were racing 03-termi on mwce
